HJ75 E Locking Axles Front and Rear
I have a set of complete axles that came with a project--was told they are from a HJ75 truck--most likely 95 or newer. Both axles have electronic lockers (most likely 24 volt) and disk brakes. Rear axle is full floating and front axle as Aisin manual locking hubs. I haven't had them apart but every thing moves freely. Asking $1700.00 for the set or best offer. If you want them shipped palleting and freight charges will apply. Parts are located in Bend OR--only thing not included in the sale are the spacers on the rear axle. Here are some photos.
couple more photos of axles
More photos:
TTT
To the Top
Measurements
Just in case any one is wondering:
From backing plate/dust shield to backing plate/dust shield the axles are 4 feet wide
Spring pad is 2 3/4 inches wide
Update
The axles are 5.29 ratio---based on spinning the pinion gear and watching the wheels. The locking system is 24 volts---but with the use of a booster can easily be used with a 12 volt system. The axles have the same dimensions as 40/45 axles included spring perches.
would they be from a HZJ-75 being 95 or newer
bump bump
