Need more info:
Is the blower working? Does it work at all 4 settings?
If not any, then check fuses. Then test the blower motor itself - may need brushes.
If some speeds work and others don't - you need to repair or replace the resistor assembly. You can test the values and use ceramic resistors from an electronics shop if you don't want to pay Toyota prices.
If you get heat out of the rear heater, and your front heater blower works and your heater selector is working, then your heater core may be blocked or partially blocked. Even relatively small amounts of deposits inside the heater core will reduce performance.
Also, as it's common on 40 series, I'll mention it here... make sure your heater core is cleaned from debris such as leaves, fluff and mold etc... if air can't pass over it, then won't give you hot air.
In any case, more details would be helpful.
~John
