Howdy, I’ve tried searching for weeks but can’t find a answer.
I’ve got an Aussie HJ60 with 2H and having some dramas with the brakes...
I’ve had the rear drums machined with new shoes and cylinders, new front rotors and pads, fitted an 80 series duel diaphragm booster and a new 60 series master cyl, I’ve bled the system many times, adjusted the rear shoes correctly and the brakes are still a bit scary.
Basically what happens is I have great braking on the first push of the pedal then the second push the pedal goes real hard and brakes are poor.
After a few pumps the dash brake warning light comes on but the reservoir is full.
I’m thinking there is still air in the system somewhere and maybe an issue with the booster, vacuum line or pump behind the alternator ??
I’ve just bought some 2005 Hilux calipers to replace the stock items as I initially thought a piston has seized in the original calipers.
