Hi All i have a Hj47 and was wondering if its possible install a VDJ79 2014 Gearbox into the hj47 with a 2H Motor
Thanks for the advice I'll do what you recommend insteadThat won't really be possible. Firstly the belhousing won't bolt up, second the trans won't bolt to the 2h Belhousing. The input shaft won't work either. You would also hit the crossmembers in the chassis and need to fabricate a trans mount. Also will need a custom driveshaft to go with it. What are you trying to get? 5 cogs? If so get a h55f from a hj75 or hj60 non vacuum shift transfer.
Yeah im after a 5 speed just so its not reving its head off
