Hi, recently acquired an 82 hj47 troopy. The PO had pieced the body together from the cleanest parts of two troopys. It also got a h55f swap so he put a body lift in it fit the tranny, which ive read is common. however that was totally tht case when i got it . It actually just had a 1.75" delron puck only, no mounts in the front mounts, then nothing all the way to the back with only the .5" rubber mounts at the rear. so higher in the front technically.
I ordered a whole new set of mounts from Roger at 4crawler plus 1" body lift pucks in order to keep the tranny clearing height, and I liked the look of the 1" anyway
I installed them all yesterday and whe n igot tot the back found out that the last 2 mounts required only about .25" of BL puck. I cut down the pucks and installed. but then Istarted thinking about how the last mounts were shorter then the rest adn if maybe the other mounts were varying heights too? and I just put a bunch of even ones in now, whcih is probably not good if they are suposed to be different right?
sorry for being so long winded but does anyone know the stock heights of all the body mounts on an hj47 troopy or fj45 troopy? I never got anything to reference to start with
Thanks!
Thanks!
