HJ-60 owners I have a question
I took off my fuel seperator to clean it up and ...(you know the thing under the RT rear door area bolted to the frame) anyway....which way does it go back on? Which way does the fuel run?
If you mean which hose goes where then pipes at top and front fuel line to upper pipe. Hope that helps.
Not getting what your trying to tell me. My question is.. Which way does it mount (I know which end up) dont know which tube faces tank and which faces motor. (which way does the fuel run thru the seperator)?
Thx
My reccomendation would be to remove it and get rid of it. The old water sep.'s are notorius for un-necessarily constricting fuel flow... and chances are the PO never drained the water from it nayway and it no-longer works. Another issue is the placement. It's in a terrible place for off-roading... so. My $.02. Remove it and put a racor filter/water sep/heater under the hood. Cheers!
mounting of water
:whoops: The filter on my cruiser with a BJ 60 4 cylinder diesel in it is mounted with the screw on the top of the filter that allows you to vent fuel or air located closer to the back and away from the rail. I hope this helps. I will try and send a photo later
Stewart
