New to me 1980 HJ45. So I’m in no way a diesel expert but I know my way around a Ford 7.3 and 6.7. Also owned many Isuzu NPR diesels and do all my own maintenance etc. Here is what seems to be a major problem on this H engine. About 4 or 5 days ago I started the truck and let it warm up. I let it idle for awhile then just drove it down my long driveway and back to the barn. I turned the truck off and noticed it seemed hot. Not crazy hot but steaming and gurgling some. I’ve seen overheated engines and it just didn’t seem that hot (btw temp gauge doesn’t work). Today I started filling the radiator back up with coolant and saw that the freeze plug right behind the injector pump had popped out. I found it on the ground. We haven’t had freezing temps to cause this. So I went and got a new freeze plug and put it in then started filling with new coolant. The truck never would get full of coolant. When I got to putting in about the 9th gallon of coolant I started thinking something is wrong. It shouldn’t hold that much. Well right about that time oil started coming out what I want to call the breath tube which hangs down by the oil pan. I really thought something is wrong. Well I then went to go pull my dipstick expecting milkshake oil and instead all my new green antifreeze started pouring up out of my dipstick tube. So I’m guessing this engine has a huge hole in it somewhere allowing coolant straight into the crankcase. The truck seemed to run fine before started good etc. Although I haven’t even driven it on the road. I pulled it home and it’s only been driven around my farm and up and down the driveway. Even today it started fine before all this just to back it out of the barn. I’m assuming this engine is ruined because of overheating. I’ve seen engines with cracked heads and milkshake oil but never an immediate situation where coolant goes straight to the crankcase. Please experts let me know if there is anything I am missing! And how to proceed!
Thanks!
Jason
Thanks!
Jason
