Hitch Hauler...do u like yours?
Kailua-Kona, HI
I'm considering purchasing a hitch hauler for the FJ80 to add to my never ending list-o-crap and am looking at this one from costco.com ...
Everthere X-12
They have another design as well but I don't think I like it as much although it has a higher payload rating... maybe its just the shiny aluminum that clashes with my flat black Conferr RR...
Better Built
Can anyone comment on either or have one they'd (highly) recommend? Any drawbacks about these in general?
Thanks,
WET
Thumbs Down
I had one and only used it for one trip. I didn't mind the basket itself just didn't like the depth of the side for securing gear. Also found out the hard way that the wife forgets it is there when backing out of spots and taps the car behind her. Also lowers the departure angle of the rear and I am not talking about utilizing this off-road, I scraped and drug it over several speed bumps and high angle l;ot entrances (the ones you commonly find East of the Mississippi).
The ultimate downfall in my book was the pain in the ass it was to get to the rear let alone get into the rear. IMHO it posed more problems than it solved.
Glen
Wow! I missed that one during my search... my reasoning for getting one was for the camping gear as well. Guess I should put more thought into this.
That swing away Dr. Gil mentioned looks sweet but is way out of my price range and only carries half the weight of the others. I may have to break out Autocad and the welder and get creative to save some bucks :idea:
WET
places like Harbor Freight have these things sometimes for $50 or so. Hard to beat making one yourself.
I bought mine from Walmart for $50. POS...the thing tilted left and right because the 2" receiver tube was of low quality and quite a bit less in diameter than the receiver itself.. I replaced the tube with proper sized tubing and then added a support 1.5" beam at the end that is welded to the existing basket and the new 2" tube and I can stand my 240lb butt on either end and it barely twists.
Took a POS and turned into a pretty stout little basket. Can even stick my sons Honda 50 on it without a second thought.
i had one, used it a couple of times. was handy for hauling extra stuff to moab behind my 40...loaned it to someone to haul gas cans on a trip. loaned it to someone else to drag greasy axle shafts home....got rid of it after that. probably won't ever buy one again.
Problem, as mentioned before, is that the stock hitch rides too low, so the cargo carrier lower the departure angle.
Because I use a roof mounted tent and can't install a roof mounted rack, I modified and reinforced my rear TJM bar with inside braces to hold a bolted hitch, allowing me to use a cargo carrier on those long trips to the rain forest. But it has it's negatives.
Since I have a right side tire carrier on my TJM rear bar, I decided to do something radical:
1) I got a left side tire carrier and removed the adjustable tire holding assembly and welded on it two stacked hitch receivers.
2) I made two aluminum half size cargo carriers bolted each one to it's own steel square bar.
Then I hook both cargo carriers on the left side tire carrier on a stacked position (allowing me to open the rear door just by sliding both left dual cargo carriers to the left and the right tire carrier to the right to their widest open position).
Of course the cargo capacity of the sliding carriers is way less against a standard 500 lbs hitch mounted carrier but the advantage of it's high position and easy rear door opening is fine with me.
Since I will replace my dash HU with one that has a rearview camera input , I guess backing will be safer !!!
As mentioned above, they are cheap at harborfreight. I have one and it easily holds 500lbs. - great value for $50. Does tilt left and right a bit, but not a big deal. They are excellent for transporting messy stuff or for extra capacity, just remember that you have to unload it before you can get into your rear cargo area.
I got the Harbor Freight one- and mounted it on the front. I ran a few beads along the tube to make it fit tight in the reciever, and welded the thing together as well, sans the raised side rails. It worked well the one time I needed it offroad for a picnic in a wash, of course my front hitch receiver is quite a bit higher than a stock rear receiver. I wouldn't use it for rock crawling. It was intended for road trips when I bring extra passengers. One drawback is that you can't load a whole hell of a lot on it in front without blocking the lights/radiator.
-Spike
They're really great for transporting five 35" tires to/from the tire shop if you have a SUV! Yeah, they tilt left/right but works great in a pinch. I wouldn't hesitate to use mine again. The HF unit that I have a fold up out of the way design so that someone doesn't accidentally hit it in a parking lot.
