"Hissing" PCV Hose
Romance, MO
Wasn't sure what to title this thread....searches came up empty...
I was under the hood with the engine running for the first time today, checking the tranny fluid level. Scared me half to death - sounded like a horrible vacuum leak.
Sounded like it was coming from the PCV hose area. I had just put new hoses (2) and new PCV and grommet in last week (yes, I had to fish grommet pieces out of the valve cover!!).
The hissing went away when I pinched the hose off with my fingers. So it is just the sound of a lot of air going through the PCV hose. Amazing that thing makes such a loud hissing noice I can hear it over the engine running.
Anyone else have a noisy PCV hose? At least it is passing air!
Tim,
Just curious, did you try my method for removing the PCV valve and grommet in one piece, posted a couple weeks ago in the "270,000 mile 80" thread. I'm wondering if it will work for others.
DougM
Doug
I actually changed it just prior to seeing your post. So no, I did the common nibble around the edge until it falls in the valve cover trick.
I did get to go to Sears and buy a grabber thingy, though! Made it 47 years without one...now I have one.
I just replaced my pcv valve and grommet last week and now experiencing the hissing. I can easily pull up and away the pcv valve by hand. Is this how it is supposed to be when new? It took a lot of force to pull the old one out.
No hissing here, but my new pcv pulls right out like that too. Because the grommet is soft.
Car drives normal but is there any long term affect if leave this leak unattend? Or anyone knows if there is a thicker grommet that is direct replacement? TIA
Sent from my iPhone using IH8MUD
Is it actually leaking?
Are you using the OEM hose?
I'm curious because I'm *not using the OEM hose and i don't seem to have this hissing. Maybe this weekend i will see if wiggling the hose can cause it. I'm using 3/8" pcv hose from autozone, because i have it routed through a baffled catch can.
The hissing at the grommet is clearly heard standing in front of the truck when the engine is running. I have aftermarket hose routed to the catch can.
Any kind of noise from the pcv is abnormal. Fix it. Replace as needed. Unmetered air especially at that vac port will cause unwanted issues such as a lean condition.
Since it is OEM replacement and leaking I really dont know if I should try to get another grommet. I measured the diameter of the pcv valves because I thought no way the new pcv is smaller but they are the same size for obvious readon.
No hissing on my 97 with new OEM PCV, grommet, and hose. I would fully expect lean condition with a leak (hiss), as noted a few times above. Best to fix by R&R parts again.
