hilux surf dc drive shaft on hdj80? (1 Viewer)
Philippines
can i put a hilux surf double cardan drive shaft to my hdj80 92 model??a 4x4 enthusiast here told me that the drive shaft of the hilux surf is ok with my 80.is this so??need some advice here..
This is a mates he used a hilux and his 105 series front shaft and had them dabbed together , it got rid of the vibration as his 105 was awd with big lift
I think the bolt holes were same space appart or something
There is some aftermarket flanges with multiple patterns in them, otherwise you can drill your own if you know what your doing. When I put the split case where the full time case was I swapped the t-case flanges for different ones and drilled them on the press, I actually used the driveshaft set on the flange (self aligning center on flange and d-shaft) to get the holes in the right place the first time.
