I posted a thread in the truck section but do not think I will get much response,can anyone give me some feedback on the reliability of the 2.4 turbo diesel Hilux 1992.
2.4 diesel Hilux motors are pretty slow, but they are damn reliable, so long as the timing belt is changed at the correct intervals.
If you break a belt the top end suffers considerable damage on these motors.
If you get a 2.4D, and don't know for certain when the last time the belt was replaced, put a new one on straight away, and have some piece of mind.
They are a great motor offroad, and give good fuel economy as well.
The hilux is a good vehicle for offroad work.
Put a load in the tray and a hill in front of them on the highway, and they are slow.
The first hilux diesels were 2.2's, followed by 2.4 then 2.8.
All very reliable.
Also, if a timing belt snaps.. It doesn't break anything in most cases, just install a new one and you good to go. I have seen people replace their engines due to timing belts, and sold the engines for cheap and the lucky buyers have just put a new belt in and run them.
Dont excagerate this problem, just be aware of this. Its quite easy to check to, if it uses coolant you have a problem, if not... Well!
All diesel engines are interference engines due to the combustion chamber design and compression ratio.
If the timing belt breaks, then you're after very, very significant repairs. With the bucket/shim system for adjusting the valve clearance (late 2LT, 2LTE and 3L), there is no forgiveness and any timing belt failure is catastrophic to the engine. When the pistons come up and hit the valves, you're looking at bent valves which destroy the valve guides - meaning that you either need to replace the whole head, or replace the guides and valves.
This is no exaggeration. It is the reality of the situation. The same thing applies to the 1HZ, 1HDT and others...
~John
~John
believe what you will...
ALL the L/N series engines are ****.
period.
gutless, all have head issues, none have decent fuel milage.
they don't even make good boat anchors.
~John
and as for 30 mpg... down hill with a tail wind and the engine shut off...MAYBE.
you like them, bully for you. it is your favorite engine, bully for you.
do a search, then you will become informed. till then ... it is all hot air.
