At first I wasn't able to get my alternator to charge. While trouble shooting I found if I unbolted the voltage regulator then after starting the vehicle pulled out the charging fuse and reinsert it the alternator clicks on and the alternator and voltage regulator begins to charge. Once the vehicle has been charging for awhile you can restart the vehicle and the alternator will charge without remove and reinsert the charge fuse. However if the voltage regulator is bolted to the correct position the alternator no longer charges.
I replaced the charge fuse, voltage regulator, alternator, checked the grounds but still have the same problem. I'm not sure where to track the cause of the problem.
Any ideas. I have a video of the problem. The buzzer stays on until I remove the charge fuse. The moment I put it back and it just touches the alternator clicks on and begins to charge and all the warning lights and buzzer stay off.
