high steer for stock power steering
my friend and I are about to do a soa on a 83 bj42 (3b,5sp,pwr steering) anyhow we found a set of kongs hy-steer arms that are tapered for one ton chevy tie rods .My issue is mating the draglink to the centerarm assembly.The diameter of the stock link is puny so in order to cut proper threads in the draglink on the stock end and cut the trheads in the steering knuckle end the tube would have to be 3/8" wall or thicker by 1.25 od dom . I think it would be very heavy and am trying to find other options.any ideas?
Sounds like only a hybrid rod will work. A lot of guys run them just are careful cutting and properly joining two rods together. Personally I would sell off the Kong arms to get away from the 1 ton tapers. A set of arms sold for a mini would bolt up and I am 99% sure the OE taper on your 83’ rod ends drop right in. Then if you ever need monster strong rods you just get a set of 1.25” DOM rods set up with FJ80 TRE’s.
Mark
