Strange... Any have an idea of the root cause?...
'79 FJ40
2F engine
Original manual trans and transfer
IGN wiring all new
Compression is good
Rochester carb (I know)
No emissions control
I was driving down the highway a few days ago and experienced the vehicle "bucking" when I got up to around 65mph (3,000 on the tach). Being very concerned, I dropped speed and got off at the next exit. I had no further issues during the rest of my trip (about 30 more minutes) on surface streets - 50 mph max.
I wouldn't characterize the problem as stalling as it runs fine at lower speeds.
I'm thinking of 2 possibilities (but certainly open to other causes)...
1. Fuel filter. I have recently switched gas tanks (cleaned the "newsed" one well before installing it). I used a glass filter with a replaceable cartrige so I could monitor it regularly. I have had a issue on 2 occasions with stalling - but the problem went away after replacement. Also, I have a rotary fuel pump but don't suspect it because I've had it for about 5 years. Could it be a fuel flow restriction from the filter?
2. Clutch. I'm not sure how much life is left in my clutch, but it does slip briefly on occasion (twice in the last 6 months) between 1st and 2nd while under high load. Not having done a clutch job before on my vehicle, is there a way to inspect the thickness of the friction material without removing the major parts of the assembly?
Any other suggestions?
Comments appreciated.
'79 FJ40
2F engine
IGN wiring all new
Compression is good
