high rpm start up
Discussion in '80-Series Tech' started by sledge916, Mar 23, 2004.
  1. sledge916
    sledge916 Media Partner
    1,593
    Media:
    1
    Albums:
    1
    103
    Jan 22, 2003
    flagstaff, Az , 86004
    Yes I searched, damn search gives no results, been that way for weeks, arrrrgggggggg!
    Just fixed the EGR troubles a couple of months ago now this, high rpm start up, this is bugging me, anybody know what to do about this?
    96 fj80
    Thanks
    Seth
  2. Brentbba
    Brentbba Former Golfer SILVER Star
    10,130
    561
    Mar 27, 2003
    OC, CA
    My '94 has always (for 10 years) started and idled at a higher RPM. I'd guess about 1800. It quickly settles down to 1000 and drops to a normal idle of 600 before to long. All depends on outside temp as well, so if you live in a cold climate engine will obviously (duh) take longer to warm up. Don't know if that helps alleviate your concerns or not.
  3. landtank
    landtank SILVER Star
    19,063
    1,264
    Mar 27, 2003
    Groveland MA
    I live in New England where temps can drop below 0 degs and have never seen higher than 1400 rpms on startup.
  4. stlcruiser
    stlcruiser
    214
    3
    Mar 29, 2003
    St. Louis Area
    Cleaning the throttle body cured my problem.
    Steve 94
  5. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    Seth,
    I seem to recall were some on this board have had good luck by cleaning the throttle body.
    There is also a write up (can't find the location @ the moment)
    were an extra o-ring is added to the valve that contols the idle
  6. nakman
    nakman addict.
    2,241
    303
    Jul 30, 2003
    Broomfield, Colorado
  7. semlin
    semlin discouraged user
    5,224
    Media:
    1
    Albums:
    1
    1,005
    Mar 27, 2003
    north of 49
    I found that just removing the throttle body, including the throttle cables, and then replacing it uncleaned also fixed the problem.
  8. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    I found that rebuilding my engine, and cleaning out the throttle body, intake, and oil pans had no effect whatsoever on the startup RPM.
  9. semlin
    5,224
    Media:
    1
    Albums:
    1
    1,005
    Mar 27, 2003
    north of 49
    Cruiserman,
    that's odd. During reassembly, did you follow your FSM and remember to fumigate the throttle body with an insense stick and then apply a voodoo incantation before torquing the lower bolts?
