High Output Alternator
Nope, You will need to fit another alternator. Not sure if yours has a vacuum pump fitted but if it does you will need one that also has the vacuum unit on it. Mine doesn't have the vacuum unit, and I think it is a 90amp alternator. Depending on where you are you should be able to exchange your original for a high output one.
Regards
D.T.
P.S. Why do you need the extra juice? Lights perhaps?
You could change the stator from wye to delta configuration, and get an adjustable regulator to increase the voltage, but it won't hit 120a. More likely around 100a.
