- Thread starter
- #21
I finally have an update to this thread. It's been awhile since I've been able to work on the 40.
I installed a Auber boost gauge on my turbo setup. Great gauge and it matches my EGT gauge. I took it for a quick test run to see what kind of boost i was getting. I was getting 3lbs in 4th gear hard to the floor. My EGT's climb very fast and I let off at 1150f. I don't run it that hot I was just testing my max boost numbers.
So I sprayed soapy water on the ducting to see if there were air leaks and there was nothing I could see. I checked the way I had wired shut the waste gate and the wire I used was allowing play in the waste gate. So I tightened it up and I got 5lbs of boost and the temps came down to 1100f max in 4th.
I wasn't happy with the wire I was using so I used some heavier gauge wire and I got 8lbs boost and the temps came down to 1030f and I can sustain 5th gear and 70 mph.
I'm very happy with the improvement but I think I the wire is not working so I'm going to fab up a bracket the will really lock it in to place. I will post up the results.
What boost numbers are normal for the 3B?
