High cold engine start-up idle fixed!!
St. Louis Area
Greetings:
Since purchasing my 80 2 years ago, the high sustained idle at start up (1800-2000) has frustrated me to no end. Tried the O-ring fix, truck did not respond properly.
Over the weekend, I cleaned the throttle body with NAPA Throttle Body and Choke Cleaner and guess what? High start up idle fixed! Cold engine high idle does not exceed 1200-1300. :cheers: Any ideas why this would solve my high idle problem?
Thanks,
Steve
94 115,000
Can anyone tell me what the fitzer valve is or where I can find the "O-ring fix" ? I am trying to troubleshoot this problem on my 80.
I have never heard of a "fitzer valve" and suspect it was BS as nobody posted on this thread again and the guy who posted that has only 4 posts - may not be here. Do a search or look in the FAQs about the high idle fix. I'll be doing it in the next few weeks.
DougM
I woudl suggest checking the fitzer valve also.
Can anyone tell me what the fitzer valve is...
I have never heard of a "fitzer valve" and suspect it was BS...
IdahoDoug, you are correct again.
The Fetzer Valve is a fictional engine component from the movie Fletch:
Willy: What the hell you need ball bearings for?
Fletch: Awww, come on guys, it's so simple. Maybe you need a refresher course. [leans arm on hot engine part]
Fletch: Hey! It's all ball bearings nowadays. Now you prepare that Fetzer valve with some 3-in-1 oil and some gauze pads. And I'm gonna need 'bout ten quarts of anti-freeze, preferably Prestone. No, no make that Quaker State.
Non-tech BS.
OK Thanks. I have been through the faqs before but I will try again.
It is causing my engine to knock sometimes during startup due to the excessive idle speed so I need it to be fixed soon.
cleaned all tb lines, egr valve, intake manifold...fixed
