HID Retrofit Coming Soon
Dallas, TX
OK.. I read all I could on this forum as well as on HIDplanet and an Acura forum on retrofitting headlights to HID.
As you may know, there arent many clear headlights out there that we can use for the retrofit so I went with the Halo lights from Ebay.
I am having a set of Valeo projectors, digital ballasts, Digital DS2 bulbs and relayed and fused harness installed in the lights.
Stay tuned for pics!
I have found a very good retrofiter on HIDPlanet who will be handling this for me.
*subscribed*
You need to see the Fantastic writeup by MikePL
https://forum.ih8mud.com/80-series-tech/182029-tutorial-hid-conversion-bling-headlights.html
I have those "Bling Headlights" with a HID retrofit - Best thing I ever did.
I also installed LED Bulbs into the Side Lamps which we use for "parking" lights here in Australia.
Now all lights are matching white :)
Citadel - Mot is the man I would be getting advice from - and product for that matter - he tests everything he sells and knows it is very good...
Check out his link in his signature...
I already had my headlights before I came accross Mot, but got my tail lights and bits and pieces from his - doing business with him was EASY, FAST and a PLEASURE!
If I can get anything from him, I will - just because he looks after me so well and knows his stuff.
Frank,
I should have paid YOU money, instead of the other way around!:D
I think citadel would do better to get his lights locally(sp) on e-bay from someone in the US, as well as the bulbs and burners, etc... ;)
I'm still interested in seeing how it turns out, as well as finding out the possible cost of having someone do the job.
Cheers!
Mot
Frank,
Cheers!
Mot
Mot,
Only telling it how it is Mate.
I reckon, once he does his headlights - like me - he will want to update all his other lights - just like I did... The other lights will look out of place - LED tail lights, clear lenses for all indicator's on guards and definitely clear lenses on the front of the car :)
He will take years off the look of his car...
And we all know, you are the expert there :)
ok.. finally after almost 10 months I got my HID retro fit back from Todd @ Retro Solutions!! If I have time I will be doing the install this weekend...
He used the ebay Halo headlights and installed Valeo projectors and Digital Ballast, bulbs and custom harness...
I'll post pics after completion!
knorrena,
I can get them, but they would be designed for the RHD application, such as found in Japan, OZ, NZ, UK, etc...
I guess it wouldn't matter if you were to do the HID projector grafting like MikePL did, but otherwise it would be a problem.
BTW, I think they're usually available on e-bay for cheap, too.
That route would be (much) cheaper since you wouldn't have to pay for international shipping and it is often directly from the wholesaler, maybe!
Mot :)
Mike or Frank...
I did notice that the ebay headlights I am using did not come with installation instructions. I've got the wiring and alignment instructions from by HID retofitter but I dont have the actual headlight installation directions. Are these direct swap outs? Do I just remove the old and bolt these on?
here are some initial pics...
Mike,
in the 3rd picture.. that is where my turn signal bulb goes correct?
Also in the 1st pic... there are some white and black wires on the bottom... do they do to my running light wiring?
Also in the 1st pic where the highbeam bulb is... there are some red and black wires...do they do to my running light wiring too?
Did you do anything to cover the exposed area of the back of the projector?
Also the gold 3 prong plug on the wire from the back of the highbeam... did you use that?
additional pics
also Mike.. I read through your install posts but a few pics were missing...
can you elaborate and include pics for the following thread:
Sealing the ballast with silicone to make sure water doesn't get in....
Ballast mounted on the underside of the headlight (in the pic it's upside down...)
The missing photos have been corrected in my thread.
Now the answers to your questions...
1. In the third picture you are pointing at the marker/corner light socket. You can turn it into a turn signal but originally it's for the corner light.
2. The black and white wires on the bottom of the housing are for the 3 LED lights. They do really look cheap so I got rid of them. If you pull the rubber covers they will pop out. I just covered the holes with hot gun glue. You can feel free to get rid of them.
3. The red and black wires are for the halo lights. You should connect them to the cables responsible for the corner lights. Watch for proper polarity as LEDs only light up with the correct polarity.
4. I covered the exposed area of the projector with rubber rings. I don't remember how I did it but I will have a look tomorrow and will post info on where I got them from.
5. I didn't use any of the connector that came with the headlights. I used the bases of the old bulbs. Just smashed the bulbs with a hammer, cut out the plastic bases, soldered them to the cables and my connection is plug and play without altering the vehicle's harness
perfect.. thanks!
