Hi Lift Jack
they are both rated at the same load spec by the manuf IIRC.
There are some vague references to the red being stronger / lasting longer, but not clear.
Would not worry about it.
better be a 60" though...
I have the black one and have never had any trouble with it. Might be better for you to think on where to mount it and to fabricate jacking points for the jack.
Kalawang
I have the black one with the red handle. They are rated exactly the same. There is a little difference on the top portion of the main bar. Otherwise there is very little difference in quality that I can see.
I'm sure the :princess: will think you're crazy for wanting a Hi-Lift for Christmas once she sees it. :D
-B-
landtank said:
It's the 60" and I have 2 jack point running down both sides of my truck just below the rockers.
check out the nifty attachment in the vendors section....
I have the red one just because there is only a $10 difference and its supposedly a little better. I would feel confident using either one though as I have friends who have the black one and can not visually see a difference.
the only differences are a few parts cast vs stamped, like the foot, IIRC and maybe the top loop (?)
I never understood the paranoia about using the handle on these things. Yes, you can possibly get hurt, but you gotta ask for it. Doesn't seem that dangerous to me at all. Just remember to place the handle correctly when you swith to lower and go slow.
Of course, raising it up all the way on the truck and crawling under would be asking for it....
Eric-I don't know if you have ever used one, but don't assume they are benign. They can kill you, break your jaw or mangle your smarts in an instant. The paranoia is very justified. I don't want to get on your case, but you don't know, and if others are casual about thier use because of what you post, that's a bad thing.
If you avoid personal injury, the High-Lift can mangle your truck pretty quick as well. Have a look at Alvaro's truck and two of the big body scars are high-lift related.
With that said, the high-lift is an indispensible tool. There are times it can save the day when nothing else can, but be respectful and cautious!
Back to the original topic-I have a black High-Lift that is cast. It's factory and very unique. I also have an orange "Jack-All" from Canada that is all cast as well. I think quality wise, they are all the same, but the cast ones are cooler, so spend the extra $10. Don't forget that this year you can get green ones too-with a chrome handle. Perfect for your Jeep.
I've used mine plenty. Not so much on the truck, but several hours worth of lifting (mostly) and pulling boulders. That was a good learning curve cuz I'd have to lift at all sorts of angles, and had to deal with slipping a lot.
Of course, you can get hurt and one should not use these things carelessly. But I don't think they are *inherently* dangerous. The dangers seem to me to be operator-related, due to mistakes, not hardware-related. IOW, if you go about it smartly, recognize the potential issues, and keep a few simple rules in mind, you should be OK. Not quite the monster that some folks make them to be...
But anyway, yes, be careful out there folks...
Junk said:
This should be in outfitting :doh:
I really don't care what the other guys think as their trucks are either not as heavy ( 40, 60, 62...) or aren't typically wheeled as much (100).
The starting bid on this jack was 49.99 and from looking at the MAN-A-Fre site it was what they sell. It wasn't until actually going to the sellers site that I realised that the RED was available. If I'm out bid then I'll look into a RED, otherwise I'm stuck with the BLACK.
There is also the green 100th anniversary model and the new gray extreme model. Saves us from recoating them gray to match the 100 series trucks :-) We stopped by their Sema booth this year and they were very proud to show the new gray model. Some small changes like a different top piece that can do differnt things and a new quick release pin on the base.
When we asked them why no quick release pin on the handle they mumbled something like "libility reasons" We also gave them their new marketing idea. We were amazed that they do not sell a Hi-Lift approved spray lubricant. It would make a lot of sense. It is amazing that they have such a good product that they really have to do little new development to keep going. The new extreme is not listed on their site and I recall it being available in Dec or Jan.
They also have their own slidelock for the handle now.
I have to take this position too. I have used the "Hi-Lift" for many purposes both off-road and around the ranch, and I have never had an accident. Its very important to fully understand how the mechanism (the climbing pins) work, and to keep them clean and lubricated.
NEVER take your hand off of the handle or place it (your hand) between the jack and the vehicle. Don't jack the vehicle (or any object) to the full height of the jack....you're asking for trouble.
The "Hi-Lift" is a "Must Have" tool IMO. It can be used for many things...and I wouldn't be without one.
Like anything, it can be MIS-used also, and just because you've "done something a dozen times and never gotten hurt" doesn't mean that you won't. It means: You're really lucky...or, your "time" is just around the corner.
Always have it with you, but always respect it.
They scare the hell outta me. I have one but only under duress. Safely transporting these potential "collision rockets" can also be problematic.
I intentionally added a JDM rear license mount so that I could not put mine on my Slee tire carrier. Since I can't safely transport it now I get to leave it home....:flipoff2:
