Mace said:They are reverse cut 9" gears. They do run on the "drive" side. -
Poser said:Does this mean that you would not run one?
Thanks Nolan.
-Steve
Think about what you are saying....wngrog said:If it is used in the front it does.
These guys almost had something here. The fact that they still use r/c gears means, like all r/c D60s, if used in the rear the pinion runs on the coast side of the ring gear.
Mace said:Think about what you are saying....
If you flip the diff over you are running the Drive side of the gears if they are reverse cut..
Just like flipping the diff over you are running the "coast" side of the gears.
Eskimo said:Their test rigs (pictured on their site) suck... how much abuse are they really putting on something running leafs (with no traction bar), those 3-4" blocks, and the slide in shims?![]()
woody said:it makes even less sense that their test rigs were running open differentials...
truehi9 said:As of today 5-19-06 ZERO Hi9 breakages or oiling issues. The NASTY noises refered to were from a foreign piece of metal wedged between the pinion gear and the oil scraper. The unit with the NASTY noises is running today with the original bearings, gears, and thrustblock.
Thanks
