Hey yall im back with a question?!
Discussion in '80-Series Tech' started by stuck in GA, Jul 18, 2005.
  1. stuck in GA
    stuck in GA
    736
    Jan 10, 2005
    Farmville, VA
    I was wheelin at my cabin in North Carolina the this past weekend and I used both lockers at points in low. When I turned off the lockers after using them the rear locker stayed on. I tried driving it everywhere and turning it off and on but it wouldn't go off. So then I put it in high, (keep in mind I don't have a center diff lock switch) and i drove back to my cabin. So then I had to drive 4 hours back to my house in Atlanta and it was hell. If any of yall have done a long trip with a rear locker... well it is hell because you feel like the rubber on your tires is just peeling away by the minute.
    So im sure some of you have had this problem. My question is one how do I fix it? (and by that is it easy=do it myself, or hard=take it to a shop) keep in mind i don't know how to do to much work myself I have only done some things. Second question is it real bad for the cruiser to drive a lot on road rear locked (except for tires cause that is an obvious answer) like is the drivetrain in danger in any way? I would like to get this fixed soon as for every time I turn it burns rubber. I have a toyota specialist shop close by if it is not easy to do myself. But if yall give me some sugestions maybe I can point out where they should go with it.
    Thanks again yall and happy wheelin!
    :cheers:
  2. Trunk Monkey
    Trunk Monkey Moderator
    9,038
    1,656
    Apr 27, 2003
    Salt Lake City
  3. reffug
    reffug
    3,925
    11
    May 28, 2004
    'in dat der briar patch'
    Search function.
  4. e9999
    e9999 You want to do what...? Moderator
    16,730
    588
    Sep 21, 2003
    US
    sorry to hear that
    there is at least one thread on "how to unlock a locked locker"
    have a look
    You can also probably pull out the actuator etc...
    and no, don't drive it like that any more!
  5. woody
    woody unhelpful spotter Staff Member Admin
    10,964
    Media:
    317
    Albums:
    8
    2,957
    Jan 15, 2002
    Toquerville UT
    mmmm...
    I run my 40 with a welded diff (perma-locked) and other than added stress on the rear drivetrain and tire wear, it's not a huge deal....best bet would be to MAX tire pressure to minimize contact. I know a number of people who run daily's with spools as well with no ill effects (beyond tires).
    most likely, switch contacts....clean 'em at the diff and that may cure it. And per the others, there is a FAQ on this too.
    https://forum.ih8mud.com/showthread.php?t=13559
  6. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,226
    679
    Dec 13, 2002
    Knee deep in hookers and gin
    My actuator is dead so I drove mine about 40 miles with the rear locked. NBD. Just like a welded rear or a spool. I wouldn't reccomend it forever, but it ain't no huge thing. Unless it's snowing, then you have some weird handling issues.
    The rod that engages the dogs may be stuck. Pull out the gear, noting the position, and unstick the rod. Pull it all the way out and clean and lube. See the FAQ for details. Clean the contacts while the gear is out and you'll never know if I was right or Woodrow was. ;)
  7. stuck in GA
    stuck in GA
    736
    Jan 10, 2005
    Farmville, VA
    Thanks yall. I am going to check this stuff out and will get back to yall on it.
  8. wb1948
    wb1948
    303
    Sep 1, 2004
    austin, tx
    get 35s
  9. stuck in GA
    stuck in GA
    736
    Jan 10, 2005
    Farmville, VA
    Thanks punk!
  10. OZCAL
    OZCAL
    1,216
    3
    Nov 16, 2004
    Queensland and California
    Sooooo.....
    You got a cabin? :beer:
