- Thread starter
- #101
Will you be capping/covering the fittings?
Yes, I'm working on that. However, they are valved, so they're basically closed in the meanwhile. They only open when the inserts are inserted.
Easy fix for annoying problem today. Added glow in the dark microdots to mark the overhead spot light and door light buttons. One dot for spot, two dots for door. The green glow is not terribly far off from the green LED glow by the SOS light.
I'm eager to read your experience with this unit, as it is one I've been considering to replace my Odyssey Group 31 AGM as a solar fridge power supply. The only reviews I've seen for new units are on the 500X, and they are pretty horrible, with lots of failure to charge problems from day one. (REI's reviews, mostly.) Hopefully the 1500X and 3000X are not experiencing the same issues. Following with interest!Yeti 1500x arrived today.
No idea. Didn't touch that.Is there a fine dust pre filter/foam insert on the rear HVAC? How many pieces do you need to remove to access it?
Yeti 1500x arrived today. Fits nice behind seat as planned. Plug coming out of the rear of console also worked out perfectly. Charging at about 290 watts (ie, FAST) with cord connected directly to car battery.
Waiting on the softcase for it, and will be working on a system to strap it down to the floor for rougher offroading.
Are the Rago panels custom? I don’t see them listed on their site yet.
ironman has short webbing straps on their site in the refrigerator section.
