Thanks for the response. I think I may leave it alone for the moment then as I'm only planning on tackling stuff I'm very confident I can do without damaging things since the LC is still brand new. I know @Eric Sarjeant has installed extra outlets in this area, but he obviously has access to all the service manuals and techs who work on these things every day. I may pay for a short period of access to the online service manual and see if I can figure it out from there.@greynolds I wasn't able to open up that piece. The method wasn't obvious to me as with other panels throughout the car. I'm sure someone here must know how to do it, but I settled with partially dislodging the side panel and pulling back the edge of the strip above the cigarette lighter.
Hopefully we'll get lucky and Eric or someone else will chime in with some tips.@greynolds Yeah, I had been thinking about doing a little more on that console, but I'm going to quite while I'm ahead after successfully getting the Goal Zero cable in there.
It takes you just under the glovebox. For access to that area:Since my driver-side firewall grommet is extremely loaded now, I'll be using the passenger side grommet for additional items from this point forward. Does that take you to the glovebox? Any issues there?
Back of my hand today after spending hours fishing the Goal Zero power cable to the back of the rear console. Too bad the line, "But you should see the other guy" would not be a favorable statement in this case.
@Dangcat I'm just attaching the cable to the battery, not the alternator. That still provides hundreds of watts of charging power, according to Goal Zero, and avoids some potential issues. I'm definitely not the right guy to advise on anything beyond this one action step right now, as I'm very new to this.
The Manager30 us this along with a LiPo house battery, it manages between alt, solar, and 110v charging..Going to eventually reference the last page of posts and follow along. When my alternator finally dies (200+k) I Have been eyeing the 370 amp one. Would be nice to redirect the extra amps straight into my portable battery like you are with the Goal Zero, or redirect it to the 115V in back to increase it from 100Ws.
Any idea on how I could do a dual power source setup? So that when I transition from car on to generator power, that I don’t have to unplug my main power strip and Briefly lose power to everything plugged into that strip? It’s so I don’t lose signal/live feed when going in and out of camping mode.
Thanks for the lead on this!
Have you considered a small touch screen tablet as a monitor? Basically similar to how I do it but with a tablet instead of a laptop. You can just use cam links like me and toggle between or view multiple feeds at once. You can also send the hdmi feed wirelessly using something like the Hollyland X (small but effective) In combination with a HDMI camlink. It’s how I turn any hdmi-output camera into essentially a webcam for stream, by using a HDMI Camlink.
Gotcha. The HDMI link is just to get your computer/tablet to be able to read hdmi cameras that aren’t webcams, and the streaming part Is separate. Cam links just turn your computer into a monitor so you can see feed from comp, and from there I have the option of recording, streaming or just viewing the feed. The HDMI transmitter is just to send the signal wirelessly; The Hollyland is designed for movie directors by the way so it is very reliable but I get what you mean with wireless connections in general.That sounds like a good system for what you're doing! In my case, I'm not doing streaming though. I'm doing recorded content. 6K anamorphic vlog cinemascope. There are only a handful of monitors that can display the image adequately. Also, everything really needs to be instant on and work with the muscle memory I've developed for my other gear. I also find wireless signals problematic--interference and signal loss are never an option for me--unless you put a full-blown cinema system on the outside of the vehicle, which is not something I'd want to do for a permanent install. Really, it just comes down to an HDMI switching mechanism and one external monitor, I think, and something separate for the thermal camera. That's more about placement than monitor ability, though I've been thinking a recording monitor in case I want to record the thermal image.
