Hep me please - I already searched....
Secesh
Hep me please - I already searched....fog lights
I got a problem with some Hella 55 watt fog lamps. One went out. Then the other. I figured bulbs and put off fixing for the past few months.
I am defininately no rocket scientist when it comes to electrical stuff. A birf job, fan clutch, tranny maintenance - stuff like that is about all I'm up to. I put in the Hella crap, wiring, relays and all, but like I said I'm no rocket scientist.
So I take the Hella bodies apart today. Sitick in one new bulb to see what happens. Turn it on and it works. Replace the other bulb, reassemble everything and NADA. Replace the fuse with known good fuse. Nothing on either light.
Relay???
So I take the Hella bodies apart today. Sitick in one new bulb to see what happens. Turn it on and it works. Replace the other bulb, reasemble everything and NADA. Replace the fuse with known good fuse. Nothing on either light.
Relay???
Howdy! Yup. Try jumpering the light straight off the battery to see if it works, then check the relay or inline fuse?? John
X3, check the ground wire on that light. When mine outside lights quick working, 90% of the time it's the ground. Usually due to corrosion or just have a bad ground in the first place that shifted over and now it doesn't work at all. Usually just giggling the light mount and/or wires will cause it to work, then find a better ground situation.
Good luck.
Well I'm a complete dumb butt. Put in a new relay, fuse and nothing. Straight lined to the battery and the lights worked.
Wiggled the wires around and saw some sparking at the battery terminal. Tightened the positive clamp and everything works like a charm.
I am such an idiot when it comes to 12V wiring stuff. Thanks guys.
