HELP!!!
Discussion in '60-Series Wagons' started by BigSur, Mar 23, 2004.
  1. BigSur
    BigSur
    1,637
    Feb 11, 2004
    Big D
    Just went out to the truck to go and get something for lunch and when i started her up the first 30 seconds were fine but BAM...i hear this horrible screeching sound and smoke started come from under the hood. I immediatly shut the engine off.
    I take a look under the hoon and it looks like the AC idle pulley seized up and the belt started rubbing and smoking. Well i am here stuck at work with the truck. Can i cut the belt off and be ok? Its not hot enough to run the AC yet (thank goodness) and i want to see if it is ok to cut that belt off so i can atleast get home. I will be ordering a new AC pulley and belt for sure.
    If i can cut the belt off...how long can i go without a belt? Will anything be damaged in the mean time?
  2. Landpimp
    Landpimp GOLD Star
    15,932
    Media:
    1
    1,951
    Mar 14, 2003
    Gig Harbor WA
    you can cut the belt, if runs nothing besides the AC, so you can run it forever like this.
    I would pull the idler off, pop the bearing out and take it to a bearing house and get a replacment, prolly $10, new idler is prolly $60 from Toyota. I have done this on my fj80.........so I won't sware it works the same
    JohnH
  3. VTCruiser
    VTCruiser
    3,459
    18
    Sep 12, 2003
    Tacoma, WA
    if you're water pump and/or oil pump is driven by the same belt, driving the rig without the belt may not be the best idea...... :eek:
    but i am not 100% sure how the pulley systems on a 2F are set up, good luck!
  4. BigSur
    BigSur
    1,637
    Feb 11, 2004
    Big D
    [quote author=Landpimp link=board=1;threadid=13587;start=msg125766#msg125766 date=1080064916]
    JohnH
    [/quote]
    Hey LP, i cut the belt and turned the truck on...she no smoke this time but then BAM!!! Turns out my smog pump is siezed as well. I had a buddy look under the hood while it was squeling and he said my smog is dead. Can i cut that belt and still be safe until i get a new smog pump? Hell do i even need that dang thing?
  5. Landpimp
    Landpimp GOLD Star
    15,932
    Media:
    1
    1,951
    Mar 14, 2003
    Gig Harbor WA
    pretty sure the smog pump belt needs to stay on, it runs off the water pump....I think.
    Me wonders if your belts were maybe WAY to tight to cuase the idler and the smog pump to lock up.
    John
    [quote author=BigSur link=board=1;threadid=13587;start=msg125794#msg125794 date=1080066558]
    [/quote]
  6. Romer
    Romer fatherofdaughterofromer Moderator
    10,854
    2,154
    Sep 14, 2003
    Centennial, Colorado
    Smog pump or air pump?
    How many belts do you have? I thought there were onlt two even with AC. Did you make sure your belt to the alt is still there. If not, the elec system will die beacuse it will be all coming off the battery. You can gete a belt that will fit just the alt. On my 2F w/no AC I have a belt that drives the Air Pump and 1 that drives the Alt.
  7. BigSur
    BigSur
    1,637
    Feb 11, 2004
    Big D
    [quote author=Landpimp link=board=1;threadid=13587;start=msg125800#msg125800 date=1080066933]
    John
    [/quote]
    Well i haven't touch my belts since i got the truck 5 months ago and she's been running fine. Even on the way to work this morning she was running without a problem at all. If i loosen the belt a lil' would it be possible the Smog pump will engage and start running?
