I've already got a 99 landcruiser, but saw another 100 locally that caught my attention.
It's a 2005 with 190k, in decent shape but needs an abs motor or master rebuild (abs and vsc lights are on with the notorious beeping) . It also potentially need a door skin but might be able to be popped out, since it's not creased. Also needs the tail gate worked on.
The interior looks fairly clean other than a mystery hole where diff lock switch is on the earlier models, an aux in port next to one of the center vents and the front cup holder assy needs to be replaced. Obviously would need a good interior and exterior detail.
No rust, and has had some maintenance done, no records but it has a newer fuel filter, drive belt, newer radiator and factory hoses ect. Unknown if the timing belts been done but the bolts for everything appear to have been off before.
Only things I can see that It needs are CV boots or reclamp and possibly a steering rack if new fluid and ATP dont fix it.
So, what do you think a fair price is? Also possible the owner has the abs issue repaired.
