the search now has so many results that the signal/noise ratio is low...I spent 20 minutes digging but couldn't find much.
I've got a metal/metal high pitch sound that occurs at all speeds, but only when moving...sounds like a bad wheel bearing...can't isolate to a specific wheel from the cab with windows down. tapping brake pedal does not affect sound nor does engaging hand brake.
Anything else I should be concerned with besides bearings? 142K miles, nothing but maintenance/lube done to driveline since I bought it at 72K miles. I won't be tackling it myself, but I like to be prepared when discussing with my shop.
thanks much!
thanks much!
