OK I just gotta say that this IH8MUD thing and all the land cruiser guys are incredible!
Breathed Your advice was exactly what I was needing and maybe now I can contribute a little to this site.
As for the parking brake cog: It is shown in the FSM as the "adjuster" in the Rear Brake section under parking brake. With a small flashlight you can actually see the cog through the access hole once the rubber plug is removed and the hole is at the bottom or 6 o'clock position. To pull off the rotor........... this cog has to be rotated downward with the screwdriver to loosen it, on the DS and PS.
Once I got it loosened, I took two bolts off of the manifold heat shield as suggested earlier. I inserted these into the threaded holes on the face of the rotor and tightened them. As you tighten them the rotor will begin to loosen. I had to scavenge some longer bolts off of my FJ40 to get the rotor completely off but you get the idea. I think the bolts are 8mm and need to be about 1" long, they require a 12mm socket. My rotors had not been removed in a very long time so they were really stuck.
Knowing all of this information it took less than 10 minutes to remove the other side.
And Breathed......I drank a beer before I got started using your insrtuctions....... I think it helped!!!
Oh....then I drank another one after I got finished....as you instructed. Off to have my rotors turned in the morning..
Thanks again for everyones help!
SC
