Help with lubing my undercarriage
Arizona
I did a search but was unable to find info on lubing my undercarriage, suspension, ball joints etc... I have never done it before and was looking for some guidance and what tools are required. My father in law has a grease gun but was unsure if it would fit Toyota Zirks (not sure if thats how you spell it). He uses it one his Chevy.
The search button is your friend. Try the FAQ sticky at the top of this page.
As far as zirks there are 6, one on each U-joint, and one on each driveshaft. Don't overfill your driveshafts as it can put additional strain on the transfer case. Lots of info in this forum.
Fiveo,
Here are two recent threads related to your question:
https://forum.ih8mud.com/80-series-tech/201098-grease-fittings-97-lx450.html
https://forum.ih8mud.com/80-series-tech/198395-still-stuck-pics.html
Hopefully this will give you the info you are looking for. Also, the FAQs have a lot of information re: grease and recommendations etc.
Your FIL's grease gun should work fine but you may want to verify the type of grease he is using to make sure it is what you want to use. Otherwise, just pick one up (they're pretty cheap) along with a tube of grease you want and go for it. The flexible extension/ends are easier to use than the straight hard extension FWIW. And, unless you have a lift then you shouldn't have any issues getting the grease gun on the zirks, other than having to wiggle under the truck :)
BTW: 80's don't have "ball joints" - They have knuckles and birfs. Periodically you need to check them to insure they aren't leaking badly and that the knuckle has an adequate level of grease in it. Threads in the FAQs regarding this.
Good luck! After the first couple of times doing it you'll find it really isn't difficult at all. Most just add this to the normal routine when doing an oil change.
P.S. Here is a pic for you contained in the other threads :cheers:
Wow thanks!! What type of grease should I use or not use?
FAQs bud :idea:
There are a LOT of choices out there. I've been using Mobil 1 synthetic grease (red stuff) for the zirks, moly stuff in the knuckles. The moly stuff can be harder to find but your looking for stuff with higher a higher Molybdenum content there. Maybe others will chime in with what their favorite flavor is... :meh:
Here is a thread (yep, from FAQ links :D) discussing drive shaft lubing and the effects of over lubing the shaft zirks. Post #42 down I saw some discussion on grease recommendations for the zirks --> https://forum.ih8mud.com/80-series-tech/20022-updated-warning-greasing-rear-drive-shaft.html
Here is a direct link to the 80 series maintenance FAQs. Lots of REAL good information that Romer and others went to a LOT of trouble to come up with and present in a logical manner. I highly suggest you start at the top and take the time to read through all of it. Even if you don't need to know some it right now, it will familiarize you with what is in there for later on when you have questions. You may want to even print out specific parts or jot down notes so you don't have to go digging for it later :cool:
IH8MUD.com Forum - View Single Post - FAQ for 80/LX450 - January 27, 2008- Added Power Steering Pump
:cheers:
I could have swore by the title of his thread that he meant to post in the "Dirty Deeds Done Dirt Cheap" forum :D
Appletech Funny! I used to patrol the Knolls out by you when I worked for Ventura Co.
NAPA carries the Valvoline Palladium brand, it is %3 Moly and about $3 a tube; good for the driveshaft yolks and knuckles. Or, Valvoline SynPower, synthetic, with about %1 Moly. Ditto for the Mobil 1 synthetic for the U-joints; pump grease in them until they puke the new grease. On the driveshaft yolks, do get carried away; only enough grease until the shaft just starts to move outward. You can use something like PB Blaster to clean up the yolks/yolk seals; seems to help them puke grease IME.
How are the other service and lube projects going?
A word on moly grease: I spent some time hunting for some moly grease for my front axle rebuild and found that you have to dig a little to find the moly concentration in most grease. Also, you may have to go to an industrial lube supplier to get the right stuff. What I ended up finding was John Deere Special Purpose HD moly grease. It has 3% moly and better specs than just about anything. Besides its superior specs, there is a greater chance of finding it if you live in a rural area, since the chances of having a John Deere dealership are pretty good. I suggest this for everything except the wheel bearings. It also costs about $3.50/14oz tube, just like everything else.
