I have been wishing for a diesel for awhile to try out in a 45 cruiser (wagon or p.u.) but was having sticker shock with the $$$ the engines go for. I saw and bought a used Isuzu 4BD1 recently to give it a try because of the relative low cost....however I am wondering about a few things.
the 4BD1 is direct injected and is the same 3.9L as its Turbo charged version but mine is the NON-turbo charged one...it came out of Ford F-150 that some trucker had converted ....it was 2 wheel drive and was using a manual transmission (new process np435) with a secondary brownie transmission for the overdrive and granny gears...the NP435 bolts up to the bell housing.
First question for anyone that knows is whether the 4BD1 with 88 horsepower @2800 and torque of 181@1600 will be acceptable compared to the TURBO'd version which is 105 horse power @2500 and torque of 240@1600??? I know that the original F engine was 125 H.P. but the torque was less at 1600 RPM. According to the CIS auto web's diesel LC site the turbo engine 4BD1T is actually suppossed to have 120 H.P.
Second question is about the Transmission setup... I would plan on using 32" tires and it has the stock axles 1965 which are ???? gear ratio?? I need an overdrive so I can either use a chevy automatic transmission with OD or use some kind of a manual transmission with a high gear OR use the auxillary brownie transmission and lengthen the levers on the transfer (but this would extend the transfer a ways back possibly (though the engine may be able to postioned forward more and I have not measured the distance in comparison to what an automatic would put the front driveshaft at)) Or could you run the auxillary transmission for rear only behind the transfer case and leave it in 1:1 when in 4wd and use the auxillary overdrive for highway.
Thanks for any help here as to advice...I am hopeful that the 4BD1 will be strong enough for a mostly onroad driver. I would love to know if anyone knows someone that runs the non-turbo NPR motor.
thanks Jeff
fj45lvr@peoplepc.com
thanks Jeff
