I'm trying to wire in my new compressor switch and I was just going to grab power for the light of the switch from the switched dash lights right from the dimmer (rheostat).
So I see there is a plug going into the dimmer with 3 wires.
White/Green
Green
White/Black
I've obviously been able to surmise that the white/black wire is the ground, and have been using this as the basis of my tests. However, when I test either the white/green or green wires with my meter on DCV, I'm getting power from both of them. Note when I'm testing, I have the ignition in "ON" and the headlights on, thus the dash lights would be lit up at this point (not now cus the dimmer is unplugged).
Anyways, I thought one of these would be a dead line that feeds the lights only when the rheostat is plugged in... so why am I getting power on both?
Anyways, the end result here is to find a place to wire in the + for the lighting on my new switch so that it will dim with the rest of the dash when dimmend and turn off when they are turned off. If I should not be jumping in here, then where?
Thanks,
Phil
White/Green
Green
White/Black
Thanks,
Phil
