Gents,
Need your advise what to do. This morning, while i'm doing my routine check, i noticed a trace of formed rust that must be from the cooling water leaking out. It is on the area between the engine block and cylinder head very adjacent to where the cooling pump inlet pipe is located.
What should i do to prevent further damage to my engine if not quickly fixed? Should i remove the cylinder head and check the condition of the cylinder head gasket or just check the torque on the bolt if they were torqued properly. What number should i get from a properly torqued cylinder head bolts?
Hoping to hear from you the soonest.
cheers!
gado
cheers!
gado
