What I've done:
- Remove air cleaner, etc.
- Remove valve cover
- Remove all spark plugs
- #1 cyl @ TDC on compression
- Remove valve support block bolts
- Remove valve rocker arms/rocker arm supports/rocker arm shaft together
- Thread hose into #1 spark plug hole, juice it to 100psi with compressed air
- Attempt to compress spring on front most valve
After compressing the valve spring to the point that I can remove the keepers, I noticed that the valve itself would 'fall' about 3/16". So I did not remove the keepers for fear that the valve would fall into the cylinder.
Questions:
1) I thought the compressed air was supposed to keep the valve up? My compression is good, my 33gal air tank is juiced, I do no hear any 'hiss' of a leak. I do not hear any 'hiss' when the valve 'drops.'
2) If the valve did fall in and I am at TDC, would I still be able to grab the tip top of the valve or would it fall all the way in?
I have adjusted my valve lash many times and did not think it would be a big deal to go a few steps further. I was wrong! This is my daily driver...please respond!!!
Thank you!
Questions:
Thank you!
