Help! - Replacing Warn 6 Spine Short Hubs with 6 Spine Long Hubs
  • Thread starter NYIronPig
  • Start date
  • Watchers 2
NYIronPig
NYIronPig
New York
My early 1972 FJ40 has a very rough set of Warn 6 spine short hubs. I have a much nicer set of Warn 6 spine Long hubs on my shelf. Was going to get started on a swap, but wanted to check in here first to make sure this was an easy job? Is it as simple as unbolting the 6 bolts on each hub, slide them off and then slide the new longer hub on? Welcome any thought/advice!
IMG 1217
IMG 1218
IMG 1219
stoshzack
stoshzack
Wake Forest, NC
Fairly straight forward to install long hubs. Remove the dial face using the six Allen bolts. Slide the hub main body on the axle and install hex head bolts. There is a C washer that clips on the axle and against the inside of the hub main body. You can use an M8 bolt to pull the axle out to get the C washer/clip in place. Install dial face and Allen bolts. Be sure to grease everything and use gaskets.
Not sure on removing short hubs.
NYIronPig
NYIronPig
New York
believe the early 70's 6 spine Warn hubs don't have a ring but a bolt like seen here:
warnhub2-jpg.1622614
NYIronPig
NYIronPig
New York
Well good news is the out bolted right off and the newer installed with great ease. Looks so much better and smooth as butter with new gaskets, lube and screws.
Went to remove the 2nd hub and one of the 6 bolts has a bit of a rounded head and won't loosen with my ratchet. Lubed it good, then heated it up. Tried hand wrench, vice grips and still won't budge. 13MM socket want catch it. Any ideas other than cutting and drilling out? Any one ever use a bolt extractor like this?
Bolt Extractor Kit
New Hub on driver side:
IMG 1220
John McVicker
John McVicker
Big Pine, CA
I have not used a bolt extractor but I would think that should do the trick.
Are you using a 6 sided socket or 12 right now?
John McVicker
John McVicker
Big Pine, CA
Another thought…can’t tell for sure but it ‘looks‘ like you have enough room to use a Flare Wrench??
NYIronPig
NYIronPig
New York
Using a good quality 12 sided socket, going to try the Bolt extractor as my next stop. Ordered a set tonight.
stoshzack
stoshzack
Wake Forest, NC
Bolt Extractor Kit
I have had good luck with these on rounded heads
Similar threads
bmoonhajjar
Replies
7
Views
135
bmoonhajjar
bmoonhajjar
wpns4l
Replies
21
Views
743
middlecalf
middlecalf
kickingtires
Replies
20
Views
595
bmoonhajjar
bmoonhajjar
