I have read through quite a few of these posts, and cant find an exact match to my scenario. I think it is the amp, but am slightly less certain than I was before.
Data.
There is no sound at all
When i hit Map, Dest or Menu it says "the external system isnt connected"
The heat/AC, interanl and external temp work fine.
When I hit audio it says "Audio off"
I got into diagnostics mode by holding info and turning lights on and off 3 times, and you can see two screen shots below.
I check the fuses by the kick plate on drivers side seat and no blown fuses, i havent looked under the hood at fuses.
Any help would be greatly appreciated
Data.
