Help - missing spring shackle nuts
Discussion in '60-Series Wagons' started by iggi, Feb 20, 2009.
  1. iggi
    iggi
    89
    Media:
    1
    Albums:
    1
    6
    May 2, 2008
    Calgary
    Real time Help - what size u-bolt for spring shackle?
    Update:
    One of the ubolts on my rear axle is sheared off on both ends. :eek:
    Local parts store had a 1/2" x 3" x 8" Ubolt - which is too short and also seems really tight on the axle.
    What's the correct length?
    Is 3 inch the correct width?
    Is a Grade 5 bolt ok?
    Stock axles with a 2.5 inch Belton springunder lift.
    Thanks in advance!
  2. iggi
    iggi
    89
    Media:
    1
    Albums:
    1
    6
    May 2, 2008
    Calgary
    bump - anyone?
    Trying to get this bolted back together in time for the weekend.
  3. lehiguy
    lehiguy
    3,792
    25
    Mar 18, 2008
    Lehi, Porter Rockwell's home town
    Some parts stores stock certain U bolts, no garantee that they will have your size. I usually head to AAA Spring when I need U bolts. Find a place that can bend them, an off-road shop or a spring shop in your area.
  4. tsototh
    tsototh
    300
    1
    Jun 20, 2007
    Tuscaloosa, AL
  5. iggi
    iggi
    89
    Media:
    1
    Albums:
    1
    6
    May 2, 2008
    Calgary
    Thanks,
    I found a local spring shop (Standen's in Calgary)
    They matched up my broken bolt plus my measurement and came up with a 9/16 x 3.25 x 8.5
    A giant $10.35 each.
    Tomorrow is wrenchin day so hopefully it's the right size bolts.
  6. Trapper50cal
    Trapper50cal TEQ Frame of Mind Supporting Vendor
    6,157
    1,381
    Mar 22, 2005
    Durango, CO
    Get them torqued to spec, then go back and do it again, then go back and do it again...etc. Their weight load and duty tend to stretch new ones a bit.
