Ok, so, after getting my battery recharged, I got the 'ol beast fired up for the first time with my new carb. I'm pretty sure I have most of the (greatly simplified) vac. system plumbed correctly, but I have a few questions that I haven't been able to answer because the Trollhole carb doesn't use HAC.
Here's how I have it setup currently:
(Things in Bold are things I specifically have no idea what to do about; the rest are things I assume are correct, but could be totally eff'd up)
Dissy
- Big Vent on Top <-> Hard line in far PS firewall (is there a filter on the other side?)
- Small Vent on Top <-> Connected to PS VCV port Z and X via t-connector
- Inner Diaphragm Port: plugged
- Outer (main?) Diaphragm Port <-> Advance Port on Carb Base
Passenger Side (PS) VCV
- Ports X&Z: to the dissy (see Dissy connections)
- Port Y <-> to port on top of Air Cleaner
- Port S <-> One port on three-pronged Gas Filter on Intake Manifold
Driver Side (DS) VCV
- Port S <-> BVSV Outer Port (furthest from thermostat body)
- Port X <-> Air Cleaner
- Port Y <-> Port on Carb Insulator Plate
- Port Z <-> Top of Evap Canister 'Front'
Evap Canister
- 'Front' Port <-> DS VCV Port Z
- 'Back' Port <-> Hard line going back towards fuel tank
- Port With The Pump Dealie and Wires On It <-> Hard Line On Firewall, with nothing to connect it to (the top part of the Trollhole doesn't have the port for that hose that the stock carb had)
BVSV
- Inner Port <-> Air Cleaner
- Outer Port <-> DS VCV Port S
Brake Booster
- Only Port I Can See <-> Big vacuum inlet on Intake Manifold, with the cooling fins on it, with the little side inlet for the AC Diaphragm (Note: my brakes feel waaaay too firm, so I'm not sure if I have something plumbed wrong here?)
PCV Etc.
- Small Branch From Big Line on PS of Engine, Just Behind Dissy <-> The inlet (HIC valve?) on the underside of the Air Cleaner
- Port on Extreme Rear of Valve Cover <-> Back of Air Cleaner
- Big Line on PS of Engine, Just Behind Dissy <-> PCV Port on EGR Inlet on Intake Manifold (yes, I plugged the EGR side).
So, is anything routed wrong? Is anything missing? Is there anything I have hooked up that really doesn't need to be?
Dissy
Evap Canister
BVSV
Brake Booster
PCV Etc.
