- Joined
- Sep 11, 2005
- Threads
- 185
- Messages
- 2,997
- Location
- Ashburn, Va
- Website
- www.landcruiserheaven.com
Hey guys,
If you have been following my build thread (below in my sig - v2.0) I bought a used engine and rebuilt the top end, didnt do anything to the block as it had come with a warranty and the company I bought it from stand behind their motors.
Engine had the head rebuilt, complete valve job, all I did with the block was clean it and prep it for a new headgasket. Engine came from a rollover and it had 100k on it. I should've did the work to the block but I was tight on funds.
Got the engine in, put everything together started it up and I have this rattling noise coming from the bottom of the engine towards the front.
I installed a brand new timing cover, and i rebuilt the power steering pump, put in a new bearing. I have checked that the front main pulley is torqued to specs, I also put in new OEM belts, and OEM belts tensioners, New AC compressor, new alternator. So no hardware was reused all pulley and bearings have been replaced with OEM counterparts.
I removed the AC compressor belt and the noise is still there.
I am attaching the video please help me identify what it could be. or what I can check up on!
