Help me ID this part ... (1 Viewer)
g-man
Charlottesville VA
Changed my oil today 87 2f motor, after a recent cylinder head replacement. Mopping out some old oil from the oil filter mount and this thing popped out. Looking at the amount of sludge build up on it I assume it is from my engine and not from an old filter. Looks like a brass bushing. Inside is smooth but looks like some striations...or wear marks.
Spike Strip
Midnight Rider
City of Angels
I'm not 100% on this but it looks like the little stand-off mounts for the Coolant pipe the bolts to the head. They keep the pipe mounting flange away from the head slightly to clear the lip. Prolly fell into that black hole when the head was removed.
g-man
Charlottesville VA
Spike...the head was removed with the coolant pipe still in place. You saying there was supposed to be a spacer under the pipe?
judging from the amount of sludge on it, the piece prob came from the lifter area or the top of the head. The inside of the piece and the one end were shiny but the rest was covered in sludge.
g-man
Charlottesville VA
Second thoughts...maybe it was an external spacer and it was just sitting on the outer edge of the oil pump mount!
g-man
Charlottesville VA
Is there a spacer like this on the back of the alternator lock bolt? Between the alt and the bracket? That would be a likely place for it to fall off.
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
@Spike Strip is On the $ tonight :cool:
those " Collars " are indeed standoff's that allow the Coolant Yellow Brass pipes Mounting Tabs to Clear the engine Side Valve Lifter Cover
Pressed sheet-metal Lip or Rim
i bet u find a 12mm hex bolt in its place as a substitute ?
easy enough to re-install removing one 10mm hex bolt / nut at a time on oil cooler / heater bypass pipe
#54 in this SOR parts Diagram ..................
1968570
g-man
Charlottesville VA
Ok. I thought Spike Strip was talking about the short vertical pipe on the top of the head. Now makes sense. So this goes on the stud #55 in the image. Then the pipe flange, then the nut. Probably fell off as I DID remove the pipe from the side cover to get it out of the way. I remember the stud falling off. I'm guessing the spacer fell too and it was sitting on the edge of the oil filter mount and when I went to wipe the excess oil out of the mount I knocked it in the oil drain pan.
FJ40Jim
The Cruiser Whisperer
Lancaster, Ohio, USA
Yes, heater pipe standoff bushing. Cad plating makes it look 'brassy'. Rough finished on lathe, leaves striations on OD. It will slide loosely over an M6 bolt, but won't go over an M8 bolt.
The spacer bushing for alternator adjuster mentioned above is super size version, will slide over an M10 bolt. Not used on USA FJ60.
