What effect does the speed sensor have on the fuel injection system on the 3fe equipped 91-92s? Interesting that alldata says it plays a part in fuel injection.
I'm trying to track down a funky idle/misfire and recently I have done the following:
Smoke tested intake found and fixed vacuum leak at oil cap gasket
Fuel pulsation damper replaced
Found that the desmog guide I used has you delete the vsv for the fuel pressure regulator control, for now I have ran the fpr to vacuum 100% of the time as I threw the vsv away. But this is better than no vacuum 100% of the time
Replaced plugs rotor cap wires
Tested fuel pressure TPS water temp sensor afm all tested good
Pcv valve and grommet replaced along with most rubber parts of intake I found issue with. Boots are all new to gasket new
Throttle body cleaned
Carbon can replaced, this fixed my hissing gas cap
O2 sensors I replaced last year with denso
Just adjusted valves last week again.
2 years ago I replaced all the fuel injector connectors because they were brittle and nasty when I had the engine out. Injectors rebuilt at this time.
My idle still sucks. I do have a code 42 though, when I found this on alldata it had me thinking maybe this could play a part.
Gonna smoke test it again soon because I'm going crazy. Also my harness at the oil pressure sensor is mangled, but I don't think that would affect drivability.
