Hokie LX
Hi all,
Finally wanted to figure out my coolant level woes that have been ongoing for the entirety of my ownership. My coolant expansion tank level sits at the very bottom of the drain hose at all times. When I put more coolant in the expansion tank, it gets sucked out and never returns. Been happening the entire time I've owned the truck (50k miles). I've replaced the radiator and T's during my ownership and did a full system flush. Coolant level in the radiator is consistently at the top of the fins and does not change. No evidence of leaks elsewhere in the system. Coolant temps via scanguage are stable in the 185-205 range.
There is evidence of leaking around the radiator cap. It was replaced with a 108KPa cap (PN: 16401-67150) earlier in 2019 but same issue persists where the coolant expansion tank level drains to the bottom of the drain hose but does not replenish.
Is this a sign of the wrong pressure radiator cap? Another issue? FM states between 93-123KPa is standard. Is this a sign of excess pressure in the system?
Thanks
Thanks
