81 60 series has spark sometimes. It is not always getting signal at the negative terminal of the coil.
Also, the wiring to the noise filter on the coil is burned off.
It has Sniper EFI so I can tell when it is getting spark signal. Also the tach doesn’t move when it isn’t getting spark. it is totally random
I suspect the igniter or the pickup coil in the distributor but there seems to be no certain way to diagnose the igniter so I am hoping someone has seen these symptoms before.
thanks for reading this.
