Thanks...I ended up getting a SmittyBilt XRC10 (10,000 lbs) w/ synthetic rope.
I've seen synthetic break and I would definitely say it doesn't "fall to the ground." It doesn't carry the kinetic energy of wire, but it can still hurt you if it breaks under load.
A towel being snapped can break skin, imagine 3-4 times that kinetic force hitting you. You won't lose a limb, but you'll bleed.
I tend to use rigging slings for tree savers. They are designed with no stretch and a healthy safety factor.
They are very strong and I like that they don't have a "SlingShot" effect to them.
Mine range from 2" x 10'-- 6200# to 6" x 30'--60000#.
J
"No stretch"? Lifting slings typically stretch very little at their rated capacity but their rated capacity if far below their average break strength - the rating that off-roaders typically use.
The less strain you put on a strap, and the larger the strap, (think of strain as a percentage of average break strength) the less it will stretch - but they will still stretch. For example - a 2" strap will stretch much more than a 6" strap with the same load - because the load on the 2" strap is a higher percentage of the average break strength than on the 6".
I know there are formulas and whatnot for the WLL etc.. ?? divide the break strength by the design factor... Cranes operators have told me the formula before.. I can't remember![]()
All I know is I can take that 6" x 30' strap and pull a stuck 18 wheeler loaded with equipment out of the mud with a D10R CAT dozer all day long. I used that strap 3 days in a row for that purpose. If if can do that.... I'm completely comfortable pulling my 60 out with it or anything else that needs a helping hand on the trail.
J
WLL in the off-road industry can vary from as low as 2:1 or even close to 1:1 on some stock steel winch lines, up to 6:1 on shackles.
A 6" strap probably has a breaking strength of around 60k lbs new if the webbing is close to 10k/inch. If it is a two ply strap then double that. The stronger the webbing the less it will stretch in a recovery since the load percentage will be lower. It will still stretch 'some.' Stretch is bad in some cases (winching) but good in others (snatching). I wouldn't recommend snatching a small truck or SUV with a 6" strap b/c it won't stretch much at all and you'll feel that when the strap goes taught.
I'm ready to pull the trigger on a winch purchase and have it narrowed down to two choices: Engo Winch Model E10000S (ENGO USA E10000lbs Winch with Synthetic Winch Line) from MT just down the way from my house or the Runva 11XP-S 11000 lb (Runva 11XP-S 11000 lb 12v Recovery Winch (Built-in Wireless) Synthetic TopGear Package) shipped from Canada.
They have the same warranty, with the Runva being $50 more but also including a cover, remote, and wireless controller. The Runva is very well regarded all over and is also fully sealed, not sure about the Engo.
What's the opinion of the masses?
I know im late but thats not even close to the weight of the car. Curb weight is 4,700 from the factory. With accessories it might be up to 5k pounds. But a 3 ton factory car is absurd. its not armored.Hi All:
If you are looking for an electric recovery winch for a 80 Series Land Cruiser you need one rated at least 10K. Your rig weighs ~6K just as it left the factory (add bigger tires, heavy bumpers, etc. for more weight.)
The jury is still out on the long-term quality and reliability of these no name import electric winches. For piece of mind while out getting your rig stuck, I'd go with a quality, known brand, like a Warn, Ramsey, or Superwinch.
My US $00.02
Regards,
Alan
Being an owner of an 80 series I would say its not easy. Curb weight is approx 4700. I dont know if thats on a full tank of gas or on empty. But say you have a Warn M12000 winch. Thats 136 pounds. Plus an ARB bumper, approx 200-250 pounds, an expedition roof rack, 200 pounds, sliders, 150 pounds, a rear bumper with tire carrier and swingouts, approx 400 pounds, 50 extra gallons of fuel, 300 pounds, and 100 pounds worth of tools. that still only comes out to 1,536 pounds which barely brings the LC over 6000 pounds. So I have no clue what you could put into an LC to make it weigh 8000 pounds unless you filled the trunk with sand. I mean my weight figures are pretty close. Even a roof top tent is going to be 200 pounds MAX. If you are almost doubling your vehicles curb weight then you are doing something wrong.It's VERY easy to hit 6K on an 80. It's not absurd at all. Some of the "expedition" guys manage to hit almost 8K.
