Hi,
I have an oil leak I am having a hard time figuring out where it's coming from.
The oil accumulate underneath the steering box. It drips down the frame to the front frame rail where it drips to the pavement.
I can see it wet directly under the steering box. The oil is not red and does not smell like the power steering oil. I looked from all angles and I am pretty sure it is not the PS.
So what oil is in there? The only thing I can see is the between the shaft that comes from the steering wheel and the steering box, seems kind of wet. Does the steering box has oil in it, or grease?
Is this a common leak? I have seen number for threads on the PS pump replacement but the PS hoses and the pump seems dry.
TIA
Rami
PS. in the beggining I thought it was A/C oil but I cleaned everythign with simple green and washed all the oil off. All my A/C fittings are dry and I can't see how A/C leak will get to that location.
TIA
Rami
