Help! I'm stuck in a parking lot because my igntion is locked (1 Viewer)
Monument
Hi,
Not really much of an emergency but I'm stuck
I am currently stuck in a parking lot because of my dumb ignition lock. I can not turn the key pass the lock position. I have tried all the tricks I could find online like pulling on the steering wheel and pressing on the brake, I sprayed WD-40 down the key hole, and still have no luck. It's really annoying as well because I have the viper alarm system with keyless start and the car starts, but I can't drive it. Any suggestions on what to do?
Thanks
inkpot
All over Arizona
I think there is a bypass switch/ button in the shifter console. Remove the little plastic button to the left of the park position and depress it with a small screwdriver. I have never done it, but it has been discussed here many times. Good luck!
Parker CO
Try rocking the steering wheel left and right while you turn the key. Don't force it. Sometimes the steering lock binds against the lock cylinder.
Monument
Thank you for the responce. However I am confused will this help with the igntion or just help me get it out of park if I have to tow it?
Thanks
Traffic Land
Turn the steering wheel left and right, while turning the key.
Sometimes the key gets stuck and you need to just pull on it slightly, while you turn it.
flat earth Midwest
Just had my occasional bout with this myself. Yes, work the steering wheel back and forth as you try to turn, jiggle and try to push in and pull out the key as you try to turn it. At first, seems like a total stuck, but it will work loose if you keep at it. Note that this is AFTER you've pressed down on the emergency unlock thingee on the shifter that inkpot mentioned.
CT
This, just pop off the cover and jamb a pen straight down while moving the shifter
Monument
I appreciate all the help. The only thing I was able to accomplish is get the cruiser out of park. That's good because we are having a tow truck come pick it up. Until then I will keep working on trying to get the key to turn by moving the steering wheel.
Thanks
flat earth Midwest
Keep at it, it will free up. Gentler is better than harsh. Once I got mine free after 10 minutes, I had to play with it some more a few more starts, but found getting it to shake right to do it easier each time once I found the trick move. It's back to normal now. In 7 years, it's done this twice before, then been fine. Keep trying it before you start paying big bucks to get a tech to try to fix it. There's really nothing much wrong except things get in a bind once in awhile.
Monument
Hope it's a flat bed, you can't tow an 80 because it's AWD right?
Thanks for the responce. I will keep trying. Luckily for the tow truck it is close enough to my house and since it's AAA it will be free. But again u would really prefer to not have it be towed
AR
I had this happen to me about a month ago. I could not get the key to turn or wheel to unlock. I put it in neutral via popping off the cover on the gear shift, then tried to scoot it back a little. Then wiggled the wheel while I wiggled the key. Finally, got mad enough and yanked hard enough that it started. Probably should have been gentler, but my temper had taken over by then. I was in a "start it or break it" mood.
