When you start the truck, you will know. You can’t hurt anything in a static, driveway test. Just reach down and try to turn the driveshaft when the 4wd cable is pulled and see if the shaft is locked to the case.Thanks for the advice. All components have been disassembled, cleaned and repaired where necessary, except for the engine,
So are the pipes correct?
It seems odd to me the vacuum pipe for the 4WD system would have the pipe for the forward fitting on the control valve on the FOD go to the rear fitting of the Tcase. It would seem to me the forward fitting on the control should connect to the forward fitting on the Tcase, rear fitting to the rear fitting.
But that is how they were prior to disassembly, unless they were incorrect?
