Help identify these drain plugs
Discussion in '40- & 55-Series Tech' started by Herky, Mar 6, 2004.
  1. Herky
    Herky
    423
    Nov 1, 2003
    E. Washington
    Well the weather is getting nice and I wanted to take the cruiser out today. It still has the top off because I've been on the verge of starting the restoration since last fall :doh:. The problem is it's been leaking various fluids since I got her and I don't want to drive it without changing them all out. Keep in mind now that I bought this rig to learn on. I found the differential plugs and the oil drain plug, but I can't positvely identify the two drain plugs between the oil pan and the rear diff. I'm sure one of them is the transsmision, and the other is the transfer case (?) but I want to get all my ducks in a row before I go and start draining fluids.
    That brings me to my second question. My book says:
    "Transmission, transfer and power take-off lubricant type... SAE 90 EP gear oil"
    I bought some 80W 90 gear oil for the differentials. Is this OK do they really want me to use that for the transmission?
    I'm going to sit here and read the manual some more but if anyone has the answer I would love to hear it. I can take pictures if necessary but I'm sure that some of you guys have the undercarriage memorized anyway.
    Thanks for the help and sorry for the lame questions.
  2. Landpimp
    Landpimp GOLD Star
    15,873
    Media:
    1
    1,913
    Mar 14, 2003
    Gig Harbor WA
    there are 2 plugs on each the trany and t-case. the upper of the plugs is the fill, the lower is the drain(sorry I cant be more pricise), make sure you can get the fill plugs loose before you drain it, same goes with the diffs. Drain plugs should be the same size as the diff.....and I forget what that is.
    I think I run 80-90 in my Cruisers, don't think you can find 90 anymore.
  3. Herky
    Herky
    423
    Nov 1, 2003
    E. Washington
    Thanks LP. I found it illustrated in the manual so that helps. I'm still wondering about the fluid though. Can I really use the same fluid for the diff, transmission, and transfer case? ???
  4. Herky
    Herky
    423
    Nov 1, 2003
    E. Washington
    I just got off the phone with Autozone and they said their computer says to use the smae thing for all of them GL 4 or 5 I believe.
  5. nuclearlemon
    nuclearlemon not an addict Moderator
    16,073
    Media:
    87
    Albums:
    4
    887
    Jan 30, 2003
    meh-ico, colorado
    yes, you use the same in trans, xfer and axles. i found that buying a 5gallon bucket of 75w90 or 80w90 is the best way financially to go.
  6. Trevor
    Trevor
    883
    Albums:
    1
    1
    Mar 11, 2002
    You might already know this, but it's almost impossible to refill the cases without a gear oil pump. They cost a few bucks at the auto parts store, and are worth it.
  7. Herky
    Herky
    423
    Nov 1, 2003
    E. Washington
    Ya I need to invest in one. I made a huge mess the other day on the old F150 changing the transmission fluid. The right tools make all the difference in even the simplets applications.
  8. Trevor
    Trevor
    883
    Albums:
    1
    1
    Mar 11, 2002
    First time I changed my gear oils, I used a hand pump that was designed for water. It took so much force to pump, the end broke off and I ended up hosing the Dodge Neon beside me with gear oil. What a mess.
