- Thread starter
- #21
I broke mine at the same spot a day before a 2300+ mile round trip. I plugged the nipple with a screw loaded up with jbweld, and then i carefully drilled a hole in the tank, and used a 1/4 inch threaded hose barb. I used a ratchet with even pressure to tap the hole with the barb, backed it out, and painted the threads with jb weld. I ran it in as far as comfortable, then filleted around it. It held up fine on my trip. I did replace the radiator last feb with a 2 1/2 row brass OEM from Beno.
OK since I'm new here I need help with some terms. What is "Beno"?
