>> Hey -B, sounds like you've spoken to someone who's going down this road. <<
I lent a little moral support this afternoon. To remove the timing chain cover, both oil pans have to come off, the valve cover, spark plugs, the fan shroud, the fan, the alternator, the water pump, the thermostat housing, some blower pieces, the PS pump, the battery and holder, and the A/C has to be moved aside. The distributor has to come out, the crank pulley bolt, and the crank pulley, and I think the engine has to be raised slightly to get the pans off. I saw front sway bar spacers on the table so it probably came off. According to the FSM, the head has to come off but Dan was able to get the cover off without removing the head. (Thank goodness!) These are the big pieces... there was lots more stuff taken off (tensioners, belts, hoses, EGR modulator, wiring, ... simple stuff.)
And all this stuff has to be cleaned, gasketed, O-ringed, FIPG'd, before reassembly.
Mechanics have a tough job. My hat's off to the guys that do this day in and day out.
-B-
